Info about experience with C to HDL compilers
C4Cheema
Spain
Hi
I want to gather information,experience about C to hdl compilers
Blue Spec
Auto Pilot
Micro C
Impulse C
Catapult C
ROCCC
All they are commercial except ROCCC
Kindly add your ideas and experience
hdl compiler
First i won't called them COMPILERS ..They are HDL code synthetizers .A lot has to be INFERED from a piece of code .A compiler just replaces equivalent control structures. Here parallel structures have to be infered from sequential ones .
I use catapult .This is a very sofisticated program .Unfurtunatly is very expensive .So i only have an early version .But After a short learning curve i'm able to synthetize complex algorithms . I 'm working on a Guruswami Sudan algorithm .And there is a section called RothRuckenstein factorizer .Well this is easly written in c in a Recurrent form . But Catapult is not able to synthetize recurrent structures .SO I'M IN TROUBLE!
c hdl compiler
Hi
Two problems
1. My answer to your question
the best is "Catapult C"
2. You must consider systemcC to HDL and matlab to HDL too. If you are interested I may give more details and guidance.
tnx
hdl compilers
I recommend PICO of Synfora.
c compiler hdl
Is there any one who have experienced open source c to hdl synthesizer ;)
I am using ROCCC but finding some errors while compiling .....
catapult c, impulse c
Can you please give pros and cons in the light of your experience using those tools
For which purpose are they using it hardware design ,software design or both
As far as I experienced there is not any perfect tool in the market and some genesis don't like idea to use c to hdl
Re: C to HDL compiler
Kindly provide guidance regarding SystemC to hdl (tools++)
