Manchested
Member level 5
When a bjt switch have an inductive load connected to Emitter, is it necessary to have a diode in reversed biased between the CE junction, or else the back voltage will blow up the bjt?
What is the difference to have the diode between CE and to have it in parallel with the inductive load?
do they have the same function? and do I need a diode for both or either one is actually enough?
