Artlav
Full Member level 2
Hello.
I'm experimenting with induction heating, and put together a small unit at about 100-200W (measured at input).
http://orbides.1gb.ru/img/ih_overview.jpg
Royer oscillator type, 150kHz frequency.
Pretty much as expected, it gets a steel blade to glow in about 10 seconds.
http://orbides.1gb.ru/img/ih_glow_vis.jpg
http://orbides.1gb.ru/img/ih_glow_ir.jpg
However, the glow does not get brighter and only spread out, suggesting that the temperature is stuck around curie point.
But with steel it at least works.
If i put in a similar strip of aluminium, nothing would happen at all - the coil would overheat in about 5 seconds, and the aluminium strip is not even getting warm.
The oscillations are present in both cases, so it's not an equipment failure.
Now, i've seen videos of 2kW units melting aluminium, how is that possible if at just 10 times less there is no noticeable effect?
So, how can i get it to heat up aluminium?
Does it need different frequency/design, or it's just a case of needing more power?
