Inducor for grid tied inverter 3kw?
T
treez
Hello,
We are doing a 3kw Grid tied inverter. We need a 1mH inductor capable of carrying 25 Amps peak, and with 13 Amps RMS. Switching frequency is 17khz
(as per app note on page 23)…
https://www.st.com/web/en/resource/technical/document/application_note/CD00253868.pdf
We went through all the powder core torroids on mag-inc.com and they all need too many turns and are too physically big.
Do you know of a core material we can use with this and get a smaller inductor?
For low frequencies like 17 kHz, laminated iron respectively cut tape core with air gap is usually the preferred solution.
Reactions: treez
    T
Thanks, we cannot find off-the-shelf torroids of these, we found metglas but they don't seem to have torroid families
I didn't specifically refer to toroid form, rather thinking of SMxx transformer cores.
At which core size did you arrive? May be your expectations are unrealistic?
Reactions: treez
    T
Kool mu ...? supermendur...
yep at 17kHz, a fine metal tape wound core, cut, should give you acceptable core losses...
Reactions: treez
    T
