omkolhe
Newbie
I am designing a Folded Cascode OTA using TSMC 0.18u process in Cadence. After layout, I observed that the threshold voltage of the NMOS transistors in cascode increases by 40mV. I have connected the body terminals to ground. There is no significant change in the threshold voltages of the PMOS transistors used in the circuit. What could be the reason for the increase in the threshold voltage?
I have also tried just simulating a single NMOS transistor and observed the same increase in threshold voltage. I am using nmos3v transistors.
Thank you,
Om Kolhe
Thank you,
Om Kolhe
