Incorrect reading of Dallas iButton(DS1990A) serial number
nancy88
Newbie level 2
South Africa
Hi every1
Im trying to program a dallas key reader to read the 64 bit serial number of a DS1990A Dallas iButton. Im using MikroC and a PIC16F690.
For testing purposes im using an led which should turn on when the Dallas key is detected.This is working correctly, but the serial number that is being read is incorrect.
i declared the serial number of the key/iButton that i have as array and i compared it to the serial number being read via the 1 wire protocol, if they are the same, then a message "authorized" should be displayed on the lcd.(which is not the case)
i have followed Microchip's app note AN1199.
I initially assigned the "serial_number" variable to all 0's(see demowire.c).This is the variable that the serial number being read via the 1wire protocol is stored in. I then compared this variable to "key1"(initially assigned to the actual iButton serial no.) The 2 values were not equal which lead me to believe that the serial number being read via the 1 wire protocol was incorrect.
I have now changed "key1" to all 1's and when compared to "serial_number", the variables are equal. I'm not sure why the the serial number being read via 1wire is all 1's.
My code is posted below.If anyone has had a similar problem or has an idea on why this is happening, please let me know.
Thanx guys:smile:
//                 1-WIRE COMMUNICATION PROTOCOL                              //
// demowire.c        //
//============================== Includes ====================================//
//#include <p18f4580.h>
#include "Config.h"
#include "1wire.h"
//========================= Generic Definitions ==============================//
//#define BAUD_CONTROL                  00
// Command to read the 64-bit serial number from 1-wire slave device.
//#define READ_COMMAND_DS1990A         0x33
//============================= Variables ====================================//
// LCD module connections
sbit LCD_RS at RC0_bit;
sbit LCD_RD at RC3_bit;
sbit LCD_EN at RC1_bit;
sbit LCD_D4 at RC4_bit;
sbit LCD_D5 at RC5_bit;
sbit LCD_D6 at RC6_bit;
sbit LCD_D7 at RC7_bit;
sbit LCD_RS_Direction at TRISC0_bit;
sbit LCD_RD_Direction at TRISC3_bit;
sbit LCD_EN_Direction at TRISC1_bit;
sbit LCD_D4_Direction at TRISC4_bit;
sbit LCD_D5_Direction at TRISC5_bit;
sbit LCD_D6_Direction at TRISC6_bit;
sbit LCD_D7_Direction at TRISC7_bit;
// End LCD module connections
char txt1[] = "Authorized";
char txt2[] = "Unauthorized";
char txt3[] = "Scan Dallas Key";
//dummy keys
//const unsigned char key1[8]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};  //all 0's
const unsigned char key1[8]={0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF};    //all 1's
//const unsigned char key1[8]={0x01,0x6B,0xAE,0x2A,0x0F,0x00,0x00,0xA3};  //serial number of iButton
unsigned char serial_number[8]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
unsigned char temp,g;
//============================= Prototypes ===================================//
void CompareKey();
unsigned char Detect_Slave_Device();
//========================== Interrupt Vectors ===============================//
/*#pragma code high_vector=0x08
void interrupt_at_high_vector(void)
   _asm goto high_isr _endasm
#pragma code
#pragma code low_vector=0x18
void interrupt_at_low_vector(void)
   _asm goto low_isr _endasm
#pragma code
// Function:        void high_isr(void)
// PreCondition:    None
// Input:           None
// Output:          None
// Side Effects:    None
// Overview:        None
/*#pragma interrupt high_isr
void high_isr(void)
// Function:        void low_isr(void)
// Input:           None
// Output:          None
// Overview:        None
/*#pragma interruptlow low_isr
void low_isr(void)
#pragma code
// Function:        Main Function.
// Input:           None
// Output:          None
// Overview:        1-Wire protocol develop for DS1990A
void main(void)
   ANSEL  = 0;                        // Configure AN pins as digital I/O
   ANSELH = 0;
   C1ON_bit = 0;                      // Disable comparators
   C2ON_bit = 0;
   TRISC=0x00;
   PORTC=0x00;
   Lcd_Init();
   Lcd_Cmd(_LCD_CLEAR);               // Clear display
   Lcd_Cmd(_LCD_CURSOR_OFF);          // Cursor off
   Lcd_Out(1,1,txt3);
   //elay_ms(500);
     if (!Detect_Slave_Device())                            // Is slave present???
        PORTC.RC2=0;
     else
        PORTC.RC2=1;
        OW_write_byte (0x33);                // Send a command to read a serial number
        for(temp = 0; temp<8; temp++)
         serial_number[temp] = OW_read_byte();             // Read 64-bit registration (48-bit serial number) number from 1-wire Slave Device
        CompareKey();
//================================ END OF MAIN ===============================//
// Function:        unsigned char Detect_Slave_Device(void)
// Input:           None
// Output:          1 - Not Present   0 - Present
// Overview:        To check the presence of slave device.
        if (!OW_reset_pulse())
            return HIGH;
        else
            return LOW;
// Function:        unsigned char Comparekey(void)
// Input:           None
//CompareKey- Compares scanned Dallas key serial number to pre-defined keys
void CompareKey(void)
   if ((serial_number[0] == key1[0]) && (serial_number[1] == key1[1]) &&(serial_number[2] == key1[2])&&(serial_number[3] == key1[3]) &&(serial_number[4] == key1[4]) &&(serial_number[5] == key1[5]) && (serial_number[6] == key1[6]) &&(serial_number[7] == key1[7]))
     //PORTC.RC0=1;
     do{
         Lcd_Out(1,1,txt1);
         Delay_ms(500);
        } while(1);
   else
     //PORTC.RC1=1;
     do{
         Lcd_Out(1,1,txt2);
         Delay_ms(500);
        }  while(1);
//============================ End of demowire.c ===================================//
// 1wire.c        //
#include "Config.h"
#include "1wire.h"
//unsigned char macro_delay;
// Function:        void drive_OW_low (void)
// Input:           None
// Output:          None
// Overview:        Configure the OW_PIN as Output and drive the OW_PIN LOW.
        OW_PIN_DIRECTION = OUTPUT;
        OW_WRITE_PIN=LOW;
// Function:        void drive_OW_high (void)
// Input:            None
// Output:           None
// Overview:         Configure the OW_PIN as Output and drive the OW_PIN HIGH.
        OW_WRITE_PIN = HIGH;
// Function:        unsigned char read_OW (void)
// Input:           None
// Output:          Return the status of OW pin.
// Overview:        Configure as Input pin and Read the status of OW_PIN
        unsigned char read_data=0;
         OW_WRITE_PIN = INPUT;
         OW_PIN_DIRECTION = INPUT;
         if (HIGH == OW_READ_PIN)
                 read_data = SET;
         else
                read_data = CLEAR;
        return read_data;
// Function:        unsigned char OW_reset_pulse(void)
// Input:           None
// Output:          Return the Presense Pulse from the slave.
// Overview:        Initialization sequence start with reset pulse.
//                 This code generates reset sequence as per the protocol
        unsigned char presence_detect;
        drive_OW_low();                          // Drive the bus low
        Delay_us(480);                           // delay 480 microsecond (us)
        drive_OW_high ();                        // Release the bus
        Delay_us(70);                            // delay 70 microsecond (us)
        presence_detect = read_OW();            //Sample for presence pulse from slave
        Delay_us(410);                            // delay 410 microsecond (us)
        return presence_detect;
// Function:       void OW_write_bit (unsigned char write_data)
// Input:          Write a bit to 1-wire slave device.
// Output:          None
// Overview:        This function used to transmit a single bit to slave device.
void OW_write_bit (unsigned char write_bit)
        if (write_bit)
                //writing a bit '1'
                drive_OW_low();
                Delay_us(6);                         // Drive the bus low
                                                     // delay 6 microsecond (us)
                drive_OW_high ();
                Delay_us(64);                       // Release the bus
                                                    // delay 64 microsecond (us)
        else
                //writing a bit '0'
                Delay_us(60);                       // delay 60 microsecond (us)
                drive_OW_high ();
                                                    // Release the bus
                Delay_us(10);
                                                    // delay 10 microsecond for recovery (us)
// Function:        unsigned char OW_read_bit (void)
// Input:           None
// Output:          Return the status of the OW PIN
// Overview:        This function used to read a single bit from the slave device.
        unsigned char read_data;                       //reading a bit
        Delay_us(6);                                  // delay 6 microsecond (us)
        Delay_us(9);                                  // delay 9 microsecond (us)
        read_data = read_OW();                        //Read the status of OW_PIN
        Delay_us(55);                                 // delay 55 microsecond (us)
return read_data;
// Function:        void OW_write_byte (unsigned char write_data)
// Input:           Send byte to 1-wire slave device
// Output:          None
// Overview:        This function used to transmit a complete byte to slave device.
        unsigned char i;
        for (i = 0; i < 8; i++)
                OW_write_bit(write_data & 0x01);         //Sending LS-bit first
                write_data >>= 1;                       // shift the data byte for the next bit to send
// Function:        unsigned char OW_read_byte (void)
// Input:           None
// Output:          Return the read byte from slave device
// Overview:        This function used to read a complete byte from the slave device.
        unsigned char i, result=0;
          result >>= 1;                // shift the result to get it ready for the next bit to receive
          if (OW_read_bit())
             result |= 0x80;            // if result is one, then set MS-bit
        return result;
//============================== End of 1wire.c ==============================//
// 1wire.h        //
#ifndef _1wire_H
#define _1wire_H
//==============================  Includes  ==================================//
void drive_one_wire_low (void);
void drive_one_wire_high (void);
unsigned char read__one_wire (void);
void OW_write_bit (unsigned char write_data);
unsigned char OW_read_bit (void);
unsigned char OW_reset_pulse(void);
void OW_write_byte (unsigned char write_data);
unsigned char OW_read_byte (void);
#endif
//=============================  End of 1wire.h  =============================//
// Config.h        //
#ifndef _Config_H
#define _Config_H
#define        HIGH        1
#define        LOW         0
#define        OUTPUT      0
#define        INPUT       1
#define        SET         1
#define        CLEAR       0
//======================== 1-Wire Port Pin Definition ========================//
// This Configuration is required to make any PIC MicroController
// I/O pin as Open drain to drive 1-wire.
#define OW_PIN_DIRECTION         TRISB//7_bit
#define OW_WRITE_PIN             PORTB.RB7    //fOR pic 18f LATB.RB7
#define OW_READ_PIN              PORTB.RB7
#endif
//============================= End of Config.h  =============================//
Are you sure that you have a genuine DS1990A. The is a "grey" equivalent that is manufactured in Eastern Europe that does not conform to the Dallas timing standards
how would i be able to verify that it is genuine? The key has "iButton.com" on the face along with the serial number and the 1-Wire® trademark.
