In real input DFT,Why one term is more instead of N/2 terms?
naresh850
Full Member level 3
real valued fft
I have one query about DFT.
In DFT, when input is real, we get even symmetry magnitude spectrum.
It means that if we perform N-point DFT on a real input sequence, we'll get N separate complex DFT output terms but first (N/2 + 1) terms are independent.
Please clarify my confusion.
Thanks and regards,
Naresh
mahdithdn
Iran
real input dft
hi,
note that the first (zero index) and the last term (N/2 index) are always real (their computation deals with real calculation) so these two terms have half computational complexity.
regards
naresh850
Full Member level 3
fft output is it independent
could u please clarify it brifly
Regards
naresh850
Full Member level 3
real input to the dft
hello I got something like.
Well, for an 8-point DFT the last three
DFT samples (m=5, m=6, & m=7) are the
conjugates of the m=3, m=2, & m=1 DFT samples,
respectively. So what we say is:
The last three samples of an 8-pt DFT
give us *NO* new information about the
DFT's spectrum. (For an 8-point DFT, the
m=4 DFT sample is independent.) In fact,
once we have computed the first (N/2)+1 = 5
DFT samples, we don't need to compute the
last (N/2)-1 DFT samples.
Of course, that is only true for real-valued
input samples applied to the DFT, *AND* if the
DFT length, N, is an even number.
If N happens to be an odd number, then only the
first (N+1)/2 samples of the DFT are independent.
For example, with a 9-point DFT only the first
five DFT samples are independent.
mahdithdn
Iran
dft half first input
hi naresh850,
return back to the problem of an even 8 point DFT of real-valued signal. because the signal is real-valued we suspect that the computational complexity of DFT should be half of a DFT of a complex-valued signal. we justify our guess with the hermitian property of DFT so samples 7,6,5 are dependent to samples 1,2,3 ,respectively. hence, we need half computations in contrast with DFT of a complex-valued signal (of course only for this 6 points). but what about samples 0 and 4. I should mentioned here that referring to the forward DFT equation for calculation of samples 1,2,3 we deal with complex-valued computations, because DFT kernel is complex. but for samples 0 and 4 the kernel is 1 (exp(0)) and -1^kn (exp(-jkn)), respectively, so we deal with real-valued computations and therefore we have half the computational complexity in contrast with DFT of a complex-valued signal.
hope this will help you
naresh850
Full Member level 3
real-valued fft
The question is y m= 4 is independent of 8 point DFT for real valued input?
bulx
Full Member level 4
input to real fft
Guess it becomes clear when you look at what frequencies the FFT output corresponds to. The correspond to 0, Fs/N, 2* Fs/N, 3*Fs/N, ... (N-1) * Fs/N.
(N = Numer of points, Fs= sampling frequncy)
Given the real input, the output at Fs/N will match that at (N-1)*Fs/N, 2*Fs/N will match that at (N-2)*Fs/N, and so on. So every output has a matching pair (except when N is odd, where one frequncy Fs/2 will have no pair).
However, whether N be even or odd, there is no pair for 0 Hz, ie; FFT gives no output for f = Fs. (If it was present in the signal it would get aliased to 0). So the DC component will be unmatched and unique. This explains the +1 in your original question. Agree?
-b
naresh850
Full Member level 3
fft for real input
In N = 8 point DFT, m = 4 is unmatched in spectrum, when input is real.
at m =1,2 and 3 there is matching pair at m = 7,6,and 5.
so absolute power at m = 1,2,3 is half coz there is a matching pair.
what about absolute power at m = 4, when input is real in 8 point DFT?
Regards,
Naresh
bulx
Full Member level 4
dft real as input
you are not an easy one to please :)
Point is that the FFT output makes sense (for reals) only till half the number of points, the rest will always be the reflection. This means that, for example, the spectral component at (N-1) * Fs/N is not what the FFT output says it is, the ouput here is the spectral component at 1*Fs/N + all frequencies that alias to 1*Fs/N. If you really wanted to see the spectral component at (N-1) * Fs/N alone, then you should change your sampling frequncy to 2*Fs, after putting in an anti aliasing filter at Fs.
The value of the FFT output is proportional to the square of the amplitude of the constituent sinewave at that frequency. This is true for the "unmatched" FFT output point (in earlier example) also, in addition to all other points. That there are "reflected" values doesnt mean that the power of the constituent sines are doubled. If you think about it the reflections go on till infinity, so then if you add up reflections, all components go to infinity, which is absurd.
Perhaps you are mistaking it for the two-sided spectrum (-ve and +ve freqs), then the total power at any freq f is the sum of the powers at +f and -f.
-b
brmadhukar
Advanced Member level 3
India
fft output spectrum symmetry
hi bulx,
You are doing a pretty good job.
we know 0 corresponds to dc components. N/2+1,what does it correspond to is the basic question as I see and the secondary question is why is it real?
Your first explantion say there is no matching pair, but does not give physical explantion ....
BRMadhukar
bulx
Full Member level 4
dft real input complex output
Madhu,
In case of odd number of points, the output you mentioned would correspond to something slightly less than Fs/2. In case of N being even, it would correpsond to exactly Fs/2, which is the max frequency that can be handled by an FFT with sampling rate Fs.
I dont have an exact answer as to why is it real. From a mathematical view point it has to be real due to symmetry. From a physical view point, dont know if it is correct to say that the component at this freq looks like DC to the FFT.
-b
