Eddison
Newbie level 2
I want to make Frequency Divider as Fref/4.
If I can use static DFF in low jitter(30f) and low power(2mW) condition,
I want to design it.
However, after many different sizing in schematic simulation, I can't match provided condition.
If I increase width size of CMOS tr in 3-NAND gate, power increases.
If I increase length size of CMOS tr, power and jitter increases.
I tried PMOS width as 2~4 times of NMOS width.
The cause of jitter is mainly from fliker noise.
If the condition is hard, then is 1GHz -> 500MHz static DFF possible?
In L=180nm, for 2GHz Fref, which DFF would I select either static or dynamic?
Thank you for reading.
