Mythos
Newbie level 3
Hello,
i'll be brief
I used to program a few years ago (last project was on 2003) the 8051 family uC using assembly language. After that i went to ASIC design... anyway. I want to start a new project now (probably use C and or mixed C and Assembly code) but i want to avoid the remove chip from PCB to program, re-incert it, test it and repeat the whole process over and over and over.
I never used the JTAG, I2C, ICSP, USB or other interfaces for In Circuit Programming of the uC.
My Question is: Which is the best solution for developing a project and avoid the fuss? (I'm always referring to the 8051 family) Links with detailed instructions would be much appreciated
I would also like to know if i can flash a device using the CAN-Bus protocol
i'll be brief
