usilicone
Newbie level 3
LED is also called light emitting diodes. With the advantages of environmental friendly, efficient, long life time and energy saving, so it is regarded as the fourth generation light source. But the quality of LED lighting product is different, especially the weakness of thermal dispersion that seriously impact the performance of LED.
At present, bad heat dispersion of LED is because of the weakness of design for the heat emission structure. Heat radiation structure is not perfect, so if you need to improve heat dispersion property, can use LED thermal conductive adhesive. LED thermal conductive adhesive is used for LED circuit board, that can improve heat transfer coefficient, insure stability in use and enhance the life time and safety performance.
ZS-GF-935W LED thermal conductive adhesive , the heat conductivity coefficient is equal or greater than 0.8 W/(m·k) , the temperature range is -60℃~200℃, and it is non-toxic, non-corrosion, environmental friendly completely complied with RoHS of EU directive.
