May 31, 2003 #1 kudjung Member level 4 Joined Jan 17, 2003 Messages 77 Helped 2 Reputation 4 Reaction score 2 Trophy points 1,288 Activity points 734 Hi, Can anyone recommend me on some method to improve the sensitity of the radio reciever? Is there anything off the shelf we can use for this purpose. TIA
May 31, 2003 #2 Element7k Advanced Member level 1 Joined May 7, 2003 Messages 434 Helped 26 Reputation 52 Reaction score 19 Trophy points 1,298 Location TherealLapland Activity points 4,278 An amplifier module right after the antenna might help. (Its something like your TV boaster). Some car companies are using diversity antennas. If you have a rod antenna, tilting it slightly might help.
Jun 1, 2003 #3 T tanveerriaz Full Member level 5 Joined May 14, 2001 Messages 284 Helped 33 Reputation 66 Reaction score 23 Trophy points 1,308 Location GB Activity points 1,009 use active antenna h**p://w*w.ee.washington.edu/circuit_archive/circuits/activeant.html
Jun 1, 2003 #4 S sick_man Guest if you use an active antennna chances are all youll hear is engine noise and other road uses engines my advice is to replace your existing antenna with a cb antenna mounted in the center of the roof or on the rear flap
