I got many S1P file from network analyzer.now i want to import these file into ads .
i already import a single file but i need to import all the file at a time so that i can compare the result so pleas help in this issue.
you can import multiple S1P files and then do muliple data item simulation on your ads schematics. when you plot the graph, you can plot all into one graph so you can compare easily. hope it helps!
What I do usually is import all the s1p files then make several schematics and simulate each s1p alone. after that i export data from all simulations and plot them at external software (like dplot for example) in order to compare them.
you need to have multiple S1p on the same schematic and then you need to put port 1, port 2, ....port n and n is number of S1p files you have.
you can simulate all of it together. in data display server, just select S11 and add other parameters such as S22, S33 and Snn there! you should be able to see all in one graph that way!
i can also convert S22 and S33 .but here i want to know how to convert them all at a time.as i attached the file it is in frequency domain now i want to convert it to time domain.when i am converting it only convert S11 or S22 or S33... not all at a time
