Important things about Ericsson AT Commands<the conflict&
ha_wasfy
Member level 1
Dear all
1st i've to say that i intended to make this issue in new topic as it seems confusing to me.
The situation is as follows:I have Sony Ericsson T290 which supports at commands with an internal modem,and i tested it on hyperterminal and worked fine on it.
the problem was connecting it to microcontroller and gain access to it's internal modem using AT Command to send sms and dial,i used AT89S52 for that but unfortunately didn't work,although i tried every possible thing that could be done in software or hardware.
you can gently refer to my early posts on
And now
I asked a friend of mine he told me that i should send something before sending AT commands to the"Sony Ericsson T290" specially for the ericsson type but he told me that he doesn't remember what is it.
as i told you before i tried everything and the Mobile doesn't response to At commands via Microcontroller"AT89S52",and even AVR.
what should i do?
i read about the offline mode and online data mode and online command mode on the mobile data sheet is this related to the problem?
i also read this paragraph:-
"Configure the data communications program manually
To configure your data communications program manually:
1. Select a generic mobile phone modem driver from the list of available mobile phone modem drivers.
2. Set the Init string to AT&F
3. Set the optional setup string to Asynchronous RLP:
AT+CBST=0,0,1
Configure your facsimile communications program manually
To configure your facsimile communications program manually, select a Fax Class 2 driver. The built-in
modem supports Fax Class 1 facsimile which can be used if there are problems with the fax service or
speed of the computer, or if your fax application does not support Fax Class 2."
is it related to the problem???
i am really very confused and feel hopeless!
Please i am waiting for your help and replay
Thanks in advance
leunglhz
Junior Member level 3
I have exactly the same problem but with T68i.
If anyone know the solution please help!
davemaster
Peru, South America
Re: Important things about Ericsson AT Commands<the confl
ha_wasfy said:
Dear all
And now
what should i do?
AT+CBST=0,0,1
Thanks in advance
Greetings,
First, what you want to use, SMS or GPRS???
if your choice is SMS, you can use Text or PDU mode. For these, you don't need configure the phone as fax/facsimile.
You need only configure the sms mode: Text or PDU mode.
That sony ericsson support both modes, so, as a beginner i recommend use the text mode, as is showed in the manual in this post
Good luck!!!
Pd. need more help, send the code and schematic...
