[General] Importance of ferrite bead
ogulcan123
Member level 5
Istanbul, Turkey
Hi all,
I did a quick search on the internet and could not find a clue about this issue.
I'm using STM32F407VGT6 in my design and I couldn't manage to run the uC yet. I've just figured out that I've used 60Ω ferrite bead instead of 600Ω(FCM1608KF-601T03) and I would like to know if this is a fatal mistake or not.
Is there anyone who as an idea on the purpose or the importance of ferrite bead in a microcontroller circuit?
The full scheme is here:
https://www.st.com/content/ccc/reso...df/jcr:content/translations/en.DM00039084.pdf
The important part of the scheme is here:
Thanks.
Ogulcan
The ferrite bead is a part of a low pass filter.
It prevents the high frequency digital switching noise to influence the sensitive analog part (ADC) of the controller.
Klaus
.. it should work with 60 Ohm ferrite bead as well as with 600 Ohm ferrite bead.
That should not be an issue, at least as far as getting the thing to boot is concerned.
Regards, Dan.
Thank you for your quick replies.
So you don't advise to change it during the debugging process, right? This is the only mistake I've found in my design so far, which made me happy in fact
The microcontroller doesn't show any clue of working, even the XTAL is not working.
Ogulcan
