asic_engg
Hi
I have a digital block with standard cells that I want to add to analog block and run simulations in the cadence ICFB “analog environment”.
I can successfully import the schematics in the cadence composer as the symbols of std cells are available from foundry. However, the symbols appear as black box.
The foundry also provided us with “.spi” “.cir” and “.gds” files for the standard cells which have device information.
I want to know how I should import the above files into cadence ICFB so that I can descend the heirarchy of schematics at the device level.
I also want to know how to run simulations on digital design in “analog environment” using the spectre models provided by the technology library.
Thanks
Thanks
