I have a layout implemented in Encounter and I want to import it in Cadence Virtuoso to run on Calibre DRC, LVS, PEX.
I have the layout as a GDS file and I imported the tech library I use NangateOpenCellLibrary 45nm and I have its map file.
When I import, I use file-> import-> stream , and load the gds file then specify (NangateOpenCellLibrary) as the library name.
But when I check it, it says the drf files are not merged and many metals and layers are not defined.
Most probably I'm missing something while importing, please tell me how exactly I can import the layout into Virtuoso?
