themaccabee
Full Member level 4
I need to implement window watchdog as a separate hardware component in a project.
So I was considering the chip NCV8668-D
https://www.onsemi.com/pub_link/Collateral/NCV8668-D.PDF
The requirement also mentions that " WD shall use a separate time base" which i fail to understand..
So which timer should be used ?The one inside the micro controller?
Can some body help me to understand the same?
Thanks
Thanks
