coolchip
Full Member level 2
digital pid
I want to control the rpm of a brushless motor with ESC(Electronic speed controller) using PID codes in PIC.
Suppose my motor is rotating at 2000 rpm detecting using hall sensor setup.Now I want it to run at 5000 rpm.The speed will be controlled by PWM signals generated by PWM module( 16-bit) in PIC hardware which is fed to ESC.
How am I gonna use the PID parameters Kp, Ki and Kd to drive the motor to desired rpm?
desired rpm = 5000
measured rpm = 2000
error = desired - measured = + 3000
C(t) = Kp*e + Ki*∫e.dt + Kd*de/dt in digital form
desired rpm = 5000
measured rpm = 2000
