To implement qpsk modulation using pskmod command in matlab requires the data bits in the range of 0:3.if i use reed solomon encoder with n=255 and k=239 from 240th bit position to 255th bit position i get data bits in the range of 1:255.Hence only 256 psk can be implemented.
But i need to implement qpsk.Is der any suitable method?Pls help.itz urgent
thanks in advance
hi,
i m final year student.
i have to simulate channel coding and viterbi decoding in matlab in following flow.
channel coding>bpsk modulation>pass through AWGN and Rayleigh fading channel>3-bit soft decision demodulation>viterbi decoding.
plse can u sent me matlab code for it urgently.
