prabhukaran3
Member level 5
Hi friends!
Looks so great to see you again... Now I am working with FPGA kits.. I hope FPGAs are almost same as micro controllers except pin configuration flexibility. I want to implement 12 RS232/422/485 ports. At any time I wil change the port configuration settings(All ports as RS-485 or 2 ports RS-232 and 6 Ports in RS-485 mode and remaining is RS-422 mode)..... Setting informations will be given by another micro controller.... Before that I need to ensure.. programmed-compiler support needed)
RS232 voltage levels +/-12V
RS485/RS422 Voltage levels +/-5V
Is it possible? If yes please specify some FPGA ICs(It should be easily
