ohadmos
Newbie level 3
Hi
I wanted to ask you a question regarding a changing load impedance and reflection coefficient.
I have a system in which the load at the end of the transmission line changes radically all the time in matter of less than 0.1 second.
In order to deliver it a maximum power I have to match it to the source and network impedance (lets say 50ohm).
I can detect at any time the incident power and returned power in order to get the reflection coefficient, and standind wave pattern.
right now we are using a 3-stub system which moves with controlled engines, and its not good enough.
I have read a bit on the use of Ferrite Tuners in antenna systems, I was thinking of matching network of a ferrite rod before the load which is voltage controlled.
We are talking about a system which operates in 28V, 150W..
Can someone here tell me if it will work, how can it work, and where do I find these tuners?
Thanks, and sorry for the long text.
