Image vhdl code in to fpga syntheis
kambhampati9
Newbie level 3
Hi
present i am doing master thesis on Image processing using Image Enhancement technique
My task is ( Image enhancement technique implement in vhdl then code send to the nexys 2 board ).
Is this board suitable for this application ?
am using 64*64 image.
if its possible,then how can i take the output from the FPGA.
can i take the output from VGA.?
I did simulation part.
I dont know how to do synthesis part,How can i assign the pin configuration of 64*64 image size,each pixel is 8 bit..
please help me sir
FvM
Super Moderator
Staff member
Bochum, Germany
That means, you have already an image memory respetively a frame buffer in your design?
You should consider a serial data stream, as involved with any digital video format. You need at least a frame sync (VSYNC) and a pixel clock as control signals to transmit the data pixels in parallel.
Assuming your image is stored in a RAM memory, this would imply a counter that sequentially scans the adddresses. Generally, you'll find a lot of digital video HDL stuff on the internet, e.g. at opencores.org or at the FPGA vendor sites.
kambhampati9
Newbie level 3
hi thank you for your reply,
I have one more question,
i have nexys2 (Diligent board).i created RAM for image.
can i take the output from VGA ?,to display the image back.
How can i assigne pins ?
Now i will read opencores.org
thank you,
FvM
Super Moderator
Staff member
Bochum, Germany
Im not using Xilinx or the Digilent board in particular. But I noticed, that a VGA reference design is available for it from Digilent. It should clarify how to connect the pins.
Rajlaxmi
Newbie level 3
Belgaum, karnataka
hey me now working on a project of processing image in VHDL. i hv got the pixel values of the image. now need to process matix in VHDL. as per ur post u said u hv done simulation no can u plz guide me with it?
aman741
Newbie level 1
Hi
please help me sir
hey . . i m also looking for thesis on image processing with vhdl.
can i have your thesis report. i want to read it . . m not getting any problem to proceed as thesis . .
can you suggest me one please.
thnx .
