image processing in c++
muhammad ejaz
Newbie level 5
i need help regarding image processing in c++ from basiclevel................
and is there any way to convert the .m(matlab file ) to c or c++
regards
Added after 12 minutes:
plz help............i m in deep trouble
dspman
Member level 2
you can conver matlab codes to c++ using Matlab compiler. But I think that you must have advanced knowledge on C++ to use the converted file.
pardal
Member level 5
dspman said:
you can conver matlab codes to c++ using Matlab compiler. file.
No, you cannot.
The so called "compiler" is not a compiler, it produces encrypted files
not C versions of the m files.
Try and see.
mondunno
the mcc command could be used, but the files generated are useless in someother IDE, unless u have the respective libraries provided by matlab. which are pretty costly
