image enhancement using fpga.
praveenvanaparthy
Newbie level 6
Newbie level 6
hi , this is praveen
am doing my project on image processing(enhancement).
this i want to implement on vertex2pro fpga kit .
i need some suggestions to do this .
i need source code .
please give me some suggestions
-how to read a image file into verilog/vhdl code .
- how to implement this image pixel by pixel .
my aim is 'take input image from monitor(memory card/image source), process this on fpga and show output on monitor'.
first of all, I suggest learning about digital logic and then start learning verilog or VHDL.
And after you have learned that ... I suggest learning how to write a project definition, and how to ask meaningful & specific questions. Those combined skills should get you well underway on your project. Good luck!
k
i am done image negative transform using matlab(S=L-1-r).
and create r.txt file .
now coming to verilog coding am try to call r.txt file into my program using
a=$fopenr('r.txt')
my image size is 128x128 (ie, ixj).
i=128, j=128.
in r.txt filr it shows pixel values from 1 to 16384 .[128*128=16384].
now my doubt is how to take pixel values into my code and how to write back into a file.
jpeg is compressed, so you would need verilog decompression functions. Easiest is text files with raw data, otherwise bitmap.
could you please give some examples for read&write text files( or bitmap) in verilog .
its important for me . please...
