Hello my name is Andrew i'm from the london uk i need your hellp. Im looking for a enginerr who can design pcb for a car audio ampilfier.This amp needs to be a class D LINKABLE ampilfier that can work on 12v/14v
Hello kris thank you for geting back to me .Were are you from? What i need is a amp with alot of power that can work on 12v/14v and can run at 4ohm 2ohms and 1ohm and can be linkable so two amps can play has one amp. Do you have msn if yes add me andrewadassa@hotmail.co.uk
Hello, Andrew!
1) How much of power?
2) >can be linkable so two amps can play has one amp - it calls "bridge schematic"
3) print "power amplifier chip" in the search and choose schematic that you like. Than we will think how to make it.
hi sir
I am vijendra from india i can design pcb layout for you i can design schematic diagram also for you as i am attached with audio since 8 years right now i am designing pcb layout as well as hardware design of a audio power amplifier drawing the power of 12000 watt RMS based on power mosfets you can contact me at vijendra26@yahoo.com i am waiting for your reply
I am interested. I have good experience using OrCAD
Sir,
I am interested in working as a PCB designer. I have good experience working as a PCB designer using OrCAD. If you are interested you can contact me at gtmtm@hotmail.com
