[PIC] illegal conversion between types int -> struct
7ezhil7
Junior Member level 2
I am trying to reuse a code for different pins in pic16f877a.For that i have use structure concept in C.I haven't completed my program.As I was a begginer to structures concept I compiled it for any syntax errors.I got [illegal conversion between types int -> struct DHT11] error.
#define _XTAL_FREQ 10000000
#include<htc.h>
#include<stdio.h>
struct DHT11
unsigned char pin;
volatile unsigned char *port;
volatile unsigned char *tris;
checkhigh(struct DHT11 *POS)
  char say = 0;		//waitforhigh
    while(!POS->pin) {
        say++;
        __delay_us(1);
        if(say > 100)return 0;
void main()
struct DHT11 OUT;
OUT.pin = 0;
OUT.port = &PORTA;
OUT.tris  = &TRISA;
I would like to know why this error arises also whether my method to reuse code for different pins would work or not.
THANKS IN ADVANCE.
#include<htc.h>
#include<stdio.h>
//declare function
char checkhigh(DHT11StructTypeDef * POS);
//declare struct type definition
typedef struct
unsigned char pin;
}DHT11StructTypeDef;
    while(!(POS->port & POS->pin))
        say++;
        __delay_us(1);
        if (say > 100) return 0;
 return 1;
void main()
char Result;
DHT11StructTypeDef DHT11;
DHT11.pin = 0;
DHT11.port = &PORTA;
DHT11.tris  = &TRISA;
Result = checkhigh(&DHT11);
Thank you for your reply sir,
I tried my code as per your suggestion.But I got error [type conflict] at while loop i.e.while(!(POS->port & POS->pin)) . I dont know why we are using (POS->port & POS->pin) rather than using POS->pin only.Also What is the use of variable 'Result'.
Please clarify my doubts sir.
Try this:
shuld be
char *port;
char *tris;
and
POS->port shuld be converted to value of pointer, not a pointer. I cant push my head working this morning, sorry
POS->port & POS->pin we are using because we are taking value of register and applying bit mask 'pin' to get only one pin value.
Hi 7ezhil7,
Obviously your code is not complete.
As a first step, and before trying to complete and later to improve the code, it should be clear why the compiler is giving syntax errors.
Syntax issues in your code (maybe there are other problems) are:
a) missing semicolon at the end of the definition of the struct
b) missing closing bracket for the function
Not necessarily a syntax error, but needed is:
c) return value outside the while loop
struct DHT11
unsigned char pin;
}[COLOR="#FF0000"][B];[/B][/COLOR]
    while(!POS->pin) {
        say++;
        __delay_us(1);
    [COLOR="#008000"][B]return 1;[/B][/COLOR]
[COLOR="#FF0000"][B]}[/B][/COLOR]
Just tested. Works! I forgot that port is a pointer, not a variable.
typedef struct
  unsigned char pin;
//declare function
void main()
  char Result;
  DHT11.pin = 0;
    while(!(*POS->port & POS->pin))
        say++;
        __delay_us(1);
 return 1;
