IIR not working on system genrator
lordy
Junior Member level 2
pilani, India
Im trying to implement 2nd order IIR filter ( direct form 1) by xilinx block set in system generator but on output im getting noise.
same filter i implemented in matlab simulink (without using xilinx block) it is working fine.
I checked till feed forward path the output of matlab simulink and system generator both are same. i think that some problem in feed back path.
Any idea whats going wrong? it will be great help
thanks in advance
:-o
Which version are you using?. I have used some FIR from xilinx sys gen. However did you meet proper input and output sample rate?.
im using xilinx 13.1 and matlab 2010a. I checked all the sample rate in my system but still its not working(problem in feed back). I implemented FIR filters they are working fine. today i will attache my .mdi file.
Thanks for support
