ignore instance by layout extraction
Junus2012
Advanced Member level 5
Italy
Hello,
I use the iprobe that break the feedback loop of the amplifier in my design to perform the stability analyses,
Now I am doing the layout, but don't know how to make the iprobe ignored by the layout so I can pass the LVS, then later I will be able to use this probe for my post-layout simulation.
Thank you in advance
Best Regards
It doesn't work like this. You can place lvsres and use it terminal as probe or add pins and place probe over your block. There might be more sophisticated solution as well.
