if vias affect crystal ???
kabaleevisu
Advanced Member level 2
Chennai,India
Hi every one
i design xilinx usb programmer board in 2 layer. Unfortunately it is not work;
i placed via in crystal part and routed whether via affect crystal ???
:roll::idea::roll:
please reply any one
I wouldn't expect a via in the crystal path to stop it oscillating. You need to post your circuits & layout.
Keith.
i placed crystal connected to via. i put the via in decoupling capacitor is it affect the crystal???
No, I don't think the via is the problem. Vias can be a problem at high frequencies but I don't usually see much effect below 500MHz. What frequency is you crystal?
Maybe post the circuit, but also check for shorts/connection problems.
Keith
One would like to see the complete wiring, including all involved layers up to the chip. The layout snippet looks like you placed a parallel capacitor to the crystal, which seems strange.
Yes please show us more, all connections between the crystal and the IC.
have you routed the USB lines differentiallly with 90 ohm impedance? Via may pick noise.. but in this case no need to suspect.
again why decopling capacitor insted of Load capacitors? it seems strange!
