If Statement in assembly
redhat
Full Member level 1
Egypt
how can i write an if statement in assembly for example :
if porta(pin0)==0 then
execute this code
else
execute this code
endif
i can't use btss because i want to execute more than one instruction if the condition is true.
thanks in advance
Willl only provide pseudocode since it's not stated which platform is used.
bit_test(test_boolean), skip on clear;
goto state_true;
state_false:
   blah blah blah
   goto state_done;
state_true:
  blah blah blah
state_done:
  bleah blah blah
hi,
for 8051 it would look something like
JNZ P1.0 labelelse ;
code ;write code for then here
JMP endlabelelse
labelelse:
code ;write code for else
endlabelelse:
code ;further code
hope this helps!
pimr
if you use avr, this an alternative:
ldi r16,0b00000000 ;load register r16 with all 0's
out DDRA, r16 ;configure PORTA for all input
in r18, PINDA ; read PINA buffer
cpi r18, 0b00000001 ; check PINA.0 =1?
brne not_1 ; if PINA.0 not 1 (null) do subroutine not_1
breq is_1 ; if PINA.0 = 1 do subroutine is_1
not_1:
is_1:
if you are using 8051 , then :
mov c,p1.0
jc notzero
the first code
notzero:
the second code
If you are using a Pic, try my assembler code generator. It writes code in Pic assembler for common constructs in programming like if, while, for etc.
i am using pic16
thank you all for your help
Hey RedHat,
You can include more than one instruction if the condition is true using BTFSS by jumping to some subprogram
BTFSS PORTB,0
call code1
call code2
BTFSS will test bit 0 of PORTB, call code1 if bit0==0,but the return instruction in the end of code1 will load the program counter with the address of the "call code2" insturction.The previous code is modified now by adding a user defined variable TEST.code1 will set bit0 of TEST before return.The program can skip "call code2" now like this :
BCF TEST,0
BTFSS PORTB,0
call code1
BTFSS TEST,0 ; was code1 executed? skip if yes,
call code2 ; execute code2 if not
BCF TEST,0
code1
BSF TEST,0
return
code2
return
Regards
Assembler is too low level to have logical sematics ,
INSTEAD these have to be done "by hand" .And basically is done with READING variables (registers or ports) compairing the read value to expected and depending of the compairaison execute a jump to some other address.
So basically :
READ is a mov or a load
COMPAIRE is cmp or another arithmetic
JUMP is jmp
on the pic you dont have other choice than btfsc/s
you can use jmp instead of calls to skip the instructions for one condition or the other:
BTFSS PORTB,0
jmp PortIs0
PortIs1 (this label is not really needed)
; execution goes here when portb,0 is 1
: here goes your code for this condition
jmp finish
PortIs0
; execution goes here when portb,0 is 0
; your code for this condition
finish
A lot of really nice replies here but I've always used this:
CJNE P0.0,#0,ELSE
;code when equal
ELSE:
;code when not equal
RET
