IE3D question - model of DRA under ie3d simulation
abdoeng
Advanced Member level 2
IE3D question pls
hi ll,i ask if any one could send me any model of DRA under ie3d simulation that i try to use wave guide method to get the amplitude and phase of reflected wave.
how i determine the block of dra althougth there is only determination of limited substrate and ground?i go nut
thanks
balaguru thavamani
Full Member level 5
Re: IE3D question pls
thanks
I think its not possible to simulate Dielectric Resonator Antenna in IE3D but it can be done in Fidelity. Both IE3D and Fidelity are from Zeland Inc.
DRA example is given in Fidelity Manual.
regards,
balaguru.
abdoeng
IE3D question pls
thanks zeland
i do it so easily using my favorite CST package
it give same results as waveguide method
i use floquet mode and periodic walls
also i get results of variable oblique angle
thanks CST
pappumaity
Junior Member level 2
thanks
regards,
balaguru.
to design DRA we can use IE3D also--------------in fidelity we can draw the structure directly------but in the case of IE3D u hav to use multi layer strcture for a DRA to get your results----first verify one------den go for other
