Idrive spread measurement
airace
Member level 4
Deep in a chip
I am trying to measure Idrive process spread for PMOS/NMOS (TSMC 0.18um). The test setup i have used is below :-
The NMOS size i used is actually 50/0.18..and simulation is with specter with conditions being Vgs =1.8 and Idrive to be measured at Vds = 1.8 v
Problem : Id is reaching Imax/Imelt of source - bulk region before Vds = 1.8v and specter linearizes the result in this region and results are wrong.
If I put in a current limiting resistor, it will vary the DC bias point of X'tor..
can someone suggest any alternative setup/workaround.. :roll:
Any help will be appreciated.
Thanks!
Regards,
@ir@ce
..also forgot to mention that, I am measuring cirrent thro' dummy voltage source...to find Idrive.
Regards,
@ir@ce
Looks like you havce set W to zero on the schematic ?
....No!..Have set it to 50u...this was a sample schamtic i made for the post
