[SOLVED] Identify this component
Ranbeer Singh
Full Member level 5
Faridabad India
Please identify the given below component. It's using in 10 micro ampere sensing circuit. It's value is U-11B 114.
Curiously Google gives the correct data sheet link as first(!) match when entering "U-11B".
It's a Gas Tube Surge Arrester.
Thanks a lot,
I searched it with printed name many time, nothing found. But now with ! Symbol found fist it.
Now my question is, how can i test it?
This kind of parts rarely goes bad, unless you discharge a lightning stroke or an unlimited source like mains voltage through it.
You'll need a high voltage source to check the trigger voltage.
