Ideas for projects in microcontroller and embedded systems
hand_guy
Newbie level 1
PLEASE TELL ME WHAT ARE THE POSSIBLE PROJECTS IN MICRO CONTROLLER AND EMBEDDED SYSTEMS.
POSSIBLE PROJECTS.
search google u will get n number of projects.simplest on is to glow the led
POSSIBLE PROJECTS.
What kind of microcontroller do you intend to use?
POSSIBLE PROJECTS.
and please put off caps while typing....its quite unpolite!!
POSSIBLE PROJECTS.
you should atlest reply after getting so many replies. Anyways try out with discover circuits site
POSSIBLE PROJECTS.
I think that your question is too general.
For a vast application, most MCU can be used, from 8-bit core to 32-bit core.
For exemple, you can do a electronic doorlock using 8-bit MCU like 8051-core, PIC, etc.
Or you can create an simple PDA using 32-bit core like ARM7 or ARM9 (TMS470-ARM7 of TI)
We can not list all possible project based on MCU. It's so big that we do not have much time to gather in a list!
Re: POSSIBLE PROJECTS.
You can do various things with microcontrollers. For instance:
1. calculator with keypad and LCD;
2. Universal controller for some appliances;
3. Lighting effects;
4. Amperemeter, ohmmeter, voltmeter;
5. Logic analyser;
6. Characteristic reader of diodes, transistors with graphical display;
7. Waveform generator;
8. Frequency meter;
9. Digital oscilloscope with graphical LCD;
10. Digital power regulator.
etc............:idea:
www.scienceprog.com
I couldn't access your website below. Please put it to rapidshare or any
similar file server. If it is possible, please send me a copy to
hieu1998@gmail.com. Thank you very much for your help.
Regards,
Hieu
yogi said:
some projects are available in my book
MY EXPERIENCE IN PROGRAMMING AVR MICROCONTROLLER IN C USING WINAVR
It is a free book. You can get it from yahoo group-booksbybibin
h**p://groups.yahoo.com/group/booksbybibin/
Bibin John
www.bibinjohn.tk
I have made a board for building a digital temperature and humidity meter.
Writing on articles to explain all softwares and details, some of them is available for download under www.TechToys.com.hk.
Tomorrow I will finish the RS232 communication and a driver for 5-way navigator switch. Then the Real time clock, eeprom, sensor, and finally the graphical LCD on plan within this week or so.
John
POSSIBLE PROJECTS.
timer is a good project you can do in pic
gsm based sms controller can also be agood project.
