ICC place_opt runs are getting failed on the same machine and sometime pass
simanoj1986
Newbie level 3
Job is failing after 5hrs of run and if it is running more than 5 hrs then job is getting passed.
I
Log file is: db=FILEX '/proj/q55x_trial/Q55xx_C0_bkup/ddr/C0_BDC/Xfer_signoff/pnr/vnc_logs/20160429/130730.22742'
IWD-Info: ==> Checking the available resources
IWD-Info: ==> Starting icc_shell!
IWD-Info: Waiting for the log file logs/place_opt.log
IWD-Info: (Fri 29-Apr-16 16:30:48) Watching icc_shell and logs/place_opt.log
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 16:35:49', Log: logs/place_opt.log (line 321)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 16:40:52', Log: logs/place_opt.log (line 332)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 16:45:53', Log: logs/place_opt.log (line 3326)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 16:50:54', Log: logs/place_opt.log (line 7078)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 16:55:55', Log: logs/place_opt.log (line 7460)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 17:00:55', Log: logs/place_opt.log (line 7460)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 17:05:55', Log: logs/place_opt.log (line 7460)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 17:10:56', Log: logs/place_opt.log (line 7460)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 17:15:57', Log: logs/place_opt.log (line 7460)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 17:20:57', Log: logs/place_opt.log (line 7460)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 17:25:58', Log: logs/place_opt.log (line 10166)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 17:30:58', Log: logs/place_opt.log (line 10304)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 17:36:00', Log: logs/place_opt.log (line 10308)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 17:41:00', Log: logs/place_opt.log (line 10456)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 17:46:00', Log: logs/place_opt.log (line 10937)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 17:51:01', Log: logs/place_opt.log (line 11123)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 17:56:01', Log: logs/place_opt.log (line 11212)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 18:01:02', Log: logs/place_opt.log (line 11392)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 18:06:02', Log: logs/place_opt.log (line 11744)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 18:11:03', Log: logs/place_opt.log (line 11974)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 18:16:03', Log: logs/place_opt.log (line 12366)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 18:21:03', Log: logs/place_opt.log (line 12707)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 18:26:04', Log: logs/place_opt.log (line 12809)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 18:31:04', Log: logs/place_opt.log (line 12811)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 18:36:05', Log: logs/place_opt.log (line 12929)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 18:41:05', Log: logs/place_opt.log (line 12929)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 18:46:05', Log: logs/place_opt.log (line 12929)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 18:51:06', Log: logs/place_opt.log (line 12929)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 18:56:07', Log: logs/place_opt.log (line 12929)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 19:01:07', Log: logs/place_opt.log (line 12930)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 19:06:08', Log: logs/place_opt.log (line 12937)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 19:11:08', Log: logs/place_opt.log (line 12945)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 19:16:08', Log: logs/place_opt.log (line 12945)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 19:21:09', Log: logs/place_opt.log (line 12945)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 19:26:09', Log: logs/place_opt.log (line 12945)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 19:31:09', Log: logs/place_opt.log (line 12945)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 19:36:10', Log: logs/place_opt.log (line 12945)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 19:41:10', Log: logs/place_opt.log (line 12945)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 19:46:11', Log: logs/place_opt.log (line 12945)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 19:51:11', Log: logs/place_opt.log (line 13426)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 19:56:11', Log: logs/place_opt.log (line 13810)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 20:01:12', Log: logs/place_opt.log (line 14104)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 20:06:12', Log: logs/place_opt.log (line 14279)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 20:11:13', Log: logs/place_opt.log (line 14583)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 20:16:13', Log: logs/place_opt.log (line 14891)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 20:21:14', Log: logs/place_opt.log (line 15158)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 20:26:14', Log: logs/place_opt.log (line 15400)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 20:31:14', Log: logs/place_opt.log (line 15589)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 20:36:15', Log: logs/place_opt.log (line 16024)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 20:41:15', Log: logs/place_opt.log (line 16147)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 20:46:16', Log: logs/place_opt.log (line 16286)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 20:51:16', Log: logs/place_opt.log (line 16490)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 20:56:16', Log: logs/place_opt.log (line 16622)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 21:01:17', Log: logs/place_opt.log (line 16827)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 21:06:17', Log: logs/place_opt.log (line 16899)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 21:11:18', Log: logs/place_opt.log (line 17056)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 21:16:18', Log: logs/place_opt.log (line 17209)
IWD-Info: icc_shell Keep-alive, Time: 'Fri 29-Apr-16 21:21:19', Log: logs/place_opt.log (line 17461)
Process terminated by kill.
IWD-Info: Sending mail to
IWD-Info: ******************************************* SUMMARY *************************************************
IWD-Info: * Errors summary : Found 0 errors
IWD-Info: *
IWD-Info: *****************************************************************************************************
IWD-Info: * Warnings summary : Found 0 warnings
IWD-Info: *
there's nothing helpful in this log.
are you running this on a network folder of sorts? maybe you are losing access/connectivity to it? this is a wild guess.
Apart from the above messages i am not getting any other message in the log file.
Same run is getting passed on one machine and on the same machine getting failed while submitting next time.
It's not even clear what you want to show with the log.
- You stopped the job because it's apparently stuck?
- A supervisor process stopped the job automatically, e.g. because a time limit is exceeded or it behaved unexpectedly?
In the latter case there would be additional information.
Thanks for your reply but i am not stopping job. Automatically job is getting terminated
Yes in job i am passing timeout 2000
But how one run is getting passed and other get failed
