IC610 license configuration .. help needed
pvnk
Member level 1
ic610 license
Hi there,
i could successfully install and run ic611 on rhel 5.2 server. now my license config utility is running through but i'm not able to access license from tool. can someone help me with this? i used an lmgrd-cdslmd setup. lmgrd runs without any errors. and lmstat -c 5280@localhost returns a healthy mesage. but tool cant access the license.
your help is highly appreciated !
thanks in advance,
PVNK
meitolake
Full Member level 3
could not get license virtuoso_schematic_editor_l
Could you show the error message?
pvnk
Member level 1
ic610 license.dat
it just says, cant get schematic L license, do you want to go for higher tiered ones, then it fails to check out any license.
error 7
meitolake
Full Member level 3
ic610 licence
Do you have run lic_error?
lic_error -7
pvnk
Member level 1
ic610 licence.dat
a little more investigation shows that licence is getting checked out and in back with the same time stamp.
cdslmd message is like this on the terminal
20.45.55 (cdslmd) OUT : "Virtuoso_Schematic_Editor_L" pvnk@localhost.localdomain
20.45.55 (cdslmd) IN : "Virtuoso_Schematic_Editor_L" pvnk@localhost.localdomain
same joke repeats for XL licence immediately. i searched in sourcelink. ther is similar problem reported, but solution says
"The reason why the licenses are getting checked in just after checked out at the
same time because the system clock from where the tool is running is out-of-sync.
Please correct the date/time setting of the system to resolve this problem."
my time is correct. any one got a clue on this? wht do they mean by out of sync? cant i set it up on a workstation? :twisted: :twisted:
thank you very much
meitolake
Full Member level 3
lmgrd ic61
Maybe the environment variables effect the time setting? Such as LC_ALL, LC_TIME and so on.
letan
Member level 3
VietNam
ic6, licence file
you set env: setenv CDSLMG_LICENSE_FILE=/IC61.../license.dat
open license file with "gedit" in line: add line "DEAMON cdslmg /IC61/share/license/license.dat"
In file rc.local at: /etc/rd/rd.local, add line: alias /IC61/tools/bin/cdslmg -c /IC6.../license.dat -l /root/IC6.log.
restart and open IC6.log file.
FEATURES will appear without errors, if it have error, the license isn't correct ,you change license file other.:D
Added after 1 minutes:
jonyRoyal
Member level 1
ic610 errors
This is very simple one........If you using old licenses for new binaries...........
this will be cause......if it orginal license you ask for cadence...otherwise you sholud work with old binaries
