IC5141 & SOC4.1 (how to make it run?)
oktan
Member level 1
Netherlands
Hi;
i got a problem with running Cadence IC5141 on my sys.
i managed to install all the IC5141 & SOC4.1 & IUS 5.5 & Assura on my pc that has CentOS 4.4.
and also i have license for this cadence product ..(it is only one file)
now comes the question that how i can set this license and how can i set the Envirement variables. plus where should i set these variables.and exactly how can i do that?
cheers
mariaR
if you had successfully installed the products, then you can read the document come with them. It's not easily to explain how to run the products in a few pages
tsinghua
Full Member level 4
You should set license variable to your licesne server or file.
And add executible to your path environment.
setenv CDS_LIC_FILE license_file_or_server
or
setenv LM_LICENSE_FILE license_file_or_server
edacw1
Full Member level 4
Which type is your license file? Floating or nodelocked? For floating, you must use the command "lmgrd" to start the license while you set "LM_LICENSE_FILE". For nodelocked, you can only set "LM_LICENSE_FILE".
red_boy
Junior Member level 1
insert the following to your csh scripts
setenv CDS_LIC_FILE 5280@hostname
set path = ($path install_path/tools/bin)
setenv LD_LIBRARY_PATH $LD_LIBRARY_PATH:install_path/tools/lib
wangrunlai
Junior Member level 2
In cadence tools, there is a special path: INSTALL_PATH/share/license/, u can rename each of your license file to license.dat, then the tools will load license once u start the tools.
Also there is lots of tools in IC5141 and SOC encounter, some command is:
icfb &
encounter &
rc &
bg_shell
if you want to know much of the command, u can type "-help" following the command.
dumeHCM
license problem
demi91
Do you have IC5141.tar ? I want to install it!
gamma1
Junior Member level 3
There are 3 CDs . Search the web, maybe you are lucky
tomdchao
send us the link, please
