cadence bash
Hi all,
as you can see I've a problem to configure my bashrc to start icfb under linux.
I've read various posts and spent 7 days but at the end it's not work, probably due to my poor familiarity with linux.
This is the situation :
I've installed IC5141 on Ubuntu, modifying SETUP.SH script to solve the problem old tar version.
At the end I wrote new lines for my .bashrc that I take from other posts.
alias schematic='/home/albert/Cadence/tools/bin/lmgrd -c /home/albert/Cadence/share/license/license.dat'
export CDS=/home/albert/Cadence
export CDS_INSTALL_DIR=$CDS/tools/dfII
#export LD_LIBRARY_PATH=/usr/openwin/lib:/usr/dt/:/usr/dt/lib:$CDS/tools/lib:$CDS/tools/verilog/lib:/usr/X11/lib:/usr/lib:/usr/X11R5/lib:$CDS/tools/leapfrog/lib
#export SHLIB_PATH=/usr/lib:/lib:/usr/lib/X11:$CDS/tools/lib:$CDS/tools/verilog/lib:$CDS/tools/leapfrog/lib
export CDS_LIC_FILE=$CDS/share/license/license.dat
export CDS_Netlisting_Mode=Analog
export PATH=$CDS/tools/bin:$CDS/tools/dfII/bin:$CDS/tools/leapfrog/bin:$CDS/tools/dracula/bin:$CDS/tools/dsm/bin:$CDS/tools/specctra/bin:$CDS/tools/pcb/bin:$PATH
export CLS_CDSD_COMPATIBILITY_LOCKING=NO
export DD_DONT_DO_OS_LOCKS=SET
#export LD_ASSUME_KERNEL=2.4.1
I've comment 3 lines that cause me come problems.
For LD_LIBRARY_PATH : No openwin or dt on my linux system. And, of course, is present X11, but a new version.
For SHLIB_PATH : Same as LD_LIBRARY_PATH.
For LD_ASSUME_KERNEL=2.4.1 : This is very strange. This line is important to eliminate the incompatibility on GLIBC2.0 in the license.dat file for successive 2.4.1 kernel versions ( I read in a post ). This is true. But If I add this line to .bashrc the shell isn't initialized correctly and this is the result
uname: error while loading shared libraries: libc.so.6: cannot open shared object file: No such file or directory
bash: [: !=: unary operator expected
bash: [: troppi argomenti
bash: [: =: unary operator expected
sed: error while loading shared libraries: libc.so.6: cannot open shared object file: No such file or directory
albert@CARONTE:~$
Can you help me ? Some doc to resolve thid problem ?
Thank you in advance for your help and sorry for my poor poor poor english!
Speedman
