ic5141 analog enviroment frozen
stevenlee
Member level 2
ic5141 usr3 was installed on RHEL AS 4 update 8, when i try to bring up the analog enviroment, it is just frozen and never opens up, any one have idea? by the way, when intalled on RHEL AS 3 update 6, there is no problem. i did try to reinstall redhat and ic5141, it looks like problem solved for the 1st time, but it comes again later on after i did some setup on my intermt.
Hughes
Advanced Member level 3
May be you have brought all the network interface down. You may use "ifconfig" to check if interface "lo" is up.
stevenlee
Member level 2
i use "ifconfig" and got the following, could you see any problem?
eth0 Link encap:Ethernet HWaddr 00:08:54:38:76:80
inet addr:192.168.0.2 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::208:54ff:fe38:7680/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:2157 errors:0 dropped:0 overruns:0 frame:0
TX packets:2187 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1971403 (1.8 MiB) TX bytes:334857 (327.0 KiB)
Interrupt:201
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:4087 errors:0 dropped:0 overruns:0 frame:0
TX packets:4087 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:1423607 (1.3 MiB) TX bytes:1423607 (1.3 MiB)
