IC Replacement for LF351
hill
Full Member level 5
lf351 replacement
Hello,
Does anyone know which op-amp IC can be used as a drop in replacement for Op-Amp IC LF351?
Thanks & best regards.
IanP
Advanced Member level 5
West Coast
ic lf351
Probably the best replacement for LF351 will be CA3140, but you can easily use TLC271, ICL7611, TLC071, TLC081, ... or if the input resistance is not big problem you can use standard, old fellow the 741 ..
    hill
