IC recommendation
poojadholam
Junior Member level 2
my task is to develop power driver(Vout = 12V, Power out = 400 W).
I have tried search IC which can provide me 12 V and 34 A at output, but I found LTM4605 which can give me 12 V and 12 A max current. I can connect this IC in parallel to get more current.
But I wonder, if there is any other IC or way to do it?
Could anyone suggest me an IC or another way?
Thank you so much in advance.
KlausST
Super Moderator
Staff member
you need to provide useful informations:
* you say "power driver" ... I don´t know what you mean with this. (most probably this is the reason why your search does not give useful results)
--> use common phrases. From the "LTM4605" I guess you want to build an SMPS. A DC/DC converter. Buck? boost? or buck-boost? Isolated or not?
* you need to provide useful values. If your device has 400W output .... then where does this power come from? I don´t expect a fuel engine. But what is it? A battery? Which type and voltage range? Any other DC supply? Or an AC supply? Mains? Which voltage?
You refer to an Linear Technology / Analog Devices part.
Why don´t you visit their internet site: https://www.analog.com/en/products/power-management/switching-regulators.html
and input the values:
other SMPS IC manufacturers have interactive selection tools, too.
Klaus
poojadholam
Klaus
I will try to explain.
Battery ----- DC/DC Converter (Buck) ----- Element
Battery is rechargeable. It provides output voltage 24 V DC (typical). It can vary between 22 V to 28 V.
The element needs 12 V power supply and 400 W Power to operate normally.
So I am searching for a Buck converter module which can provide 12 V and 34 A to my element.
KlausST
Super Moderator
Staff member
internet search: "24V 12V buck converter".
ebay, amazon and everywhere...
you may add to the search: Car, boat, truck...
I little scrolling. and 5 seconds of time.
Klaus
