IC-Prog 1.05C Problem
vcorn4
Newbie level 2
icprog privileged instruction
Hi, i'm using IC-Prog 1.05C
everytime i run the program IC-Prog 1.05C, there's always an error message pops up that says " PRIVILEGED INSTRUCTION "
do anyone familiar with this problem? please help me solve this problem. thnx
ic-prog privileged instruction
ICprog don't have acces to COM port, you need to do something like this **broken link removed**
ic prog privileged instruction
i also have the same problem
so i switched to pony prog without any problems
i think it is more easy and efficient
privileged instruction icprog
You need to install the Win NT/2k driver that is available on the IC-Prog download page. You also find the instructions there
Best Regards!
icprog privileged
First of all, I think you must use the lastest version of ICProc. The available version es 1.5D, and you are using the 1.5C.
Before you have ICProg funcionally, you must set some configuration parameters. I'm sure you are using Windows XP or 2000, so you need to install the Win NT/2k driver, it's very easy, follow this steps:
Download the attachment files, it contains the ICProg 1.5D and the Windows NT/2000 Driver.
Uncompress the ICProg and the driver in the same folder
Execute ICProg, of course it would give you the PRIVILEGED INSTRUCTION error, got to:
Settings --> Options -> Misc ; here you must mark "Enable NT/2000/XP Driver", after this accept all and restart ICProg.
The PRIVILEGED INSTRUCTION erros must be gone.
By,
GuillerMo (AR)
