IC component for DAC UNO
andihong
Member level 1
halo, i want to make DAC from arduino uno, here the link
but, there is nowhere i can buy the IC.
is there any recomendation of the IC ?
TLV2451 Operational Amplifier ( you can use almost every operational amplifier, just remember to check that is rail-to-rail).
22 uF capacitor
3.3 kOhm resistor.
there is no TLV, OPA. it's hard to find..
It's basically just an op-amp buffer stage. Replace that with another rail-to-rail opamp if you can't find it.
Here's one from Microchip (MCP600x): **broken link removed**
You can get free samples from Microchip depending on where you are. If not, they're really cheap.
If you still want to go with the TLV2451: https://www.digikey.com/product-detail/en/TLV2451CP/296-1889-5-ND/277534
