[SOLVED] IC compiler
Stirgamight
Newbie
ICC
I keep running into that error no matter how small the ring width is (I made it 0.8)
Error: The die size is too small to synthesize any power plan
(PNA-099)
Please specify smaller ring width
  • pnr.txt
What is the die size? May it be really too small to implement any ring width?
How can I know that?
Is there a command to report it? or it is just the area of the core?
Units = ???
Like, an 0.8um power ring dimension is not
likely to encompass more than a single
180nm FET or a handful of finFETs.
0.8cm, now you've got a chip scale bus ring.
do you have an empty core? trying to draw anything around it causes errors.
That was actually solved by either not mentioning the ring width at all in the command (I am not sure what the result is) or by redefining the die area with the "estimate_fp_area" command, thanks for the replies
