IC 5033 & IC 5141 problem!!
oktan
Member level 1
Netherlands
Hi everyone!
i was checking this forum about the instalation of the cadence IC5141and IC5033 but the thing is im getting totaly diffrent error in instalation.
my PC's description is:
1) OS: Mandriva 2007 powerpack+
2) i have 2 partiona one is 8.4 gb and and other is 37 gb.(mandriva did it by defoult)
3) pentinum 4 1.7 Ghz
so my questions are:
1) i have one DVD that is conatin only 3 cds in it and it is IC5141 and i have another dvd thats conatins
IC5033 with 2 folders in it (BASE (3 cds)and ISR2004xxxx(2cds!!!)! i wanna know can i replace that 2 cds with 3 cds of the IC5141!!?????
2) so for first time i installed just IC5033 and i get one error:
Specify path of install directory
[OR type [RETURN] to exit]:
/Cadence
Directory /Cadence does not exist. Create? [y/n]:
y
Creating directory /Cadence
Setting up softload for lnx86 in /Cadence
The following tar errors were detected:
/bin/tar: Removing leading `/' from member names
Could not set up SoftLoad in /Cadence
You must have write permissions to install directory
and all its subdirectories
and atleast 10 MB available disk
space in install directory.
so please guys help me out
thanx
Hi
try another folder such as
/home/cadence
you must have full access to install directory.
regards
hi hr_rezaee,
i tryed wat u sayed , "/home/cadence "also i tried "/home/<username>/Cadence"
still i get the same error.
i go in for installation with SU. so im installing as root ..i dont know y im getting this error??
cheers
hr_rezaee said:
Hi
/home/cadence
regards
thanks but it didnt work and gave same error!!
i saw some posts about the version of the TAR
what about i change the tar version to 1.3?
if u think is ok ..do u know how can i do it?imean uninstall and install the older one..
the problem is i didnt find the older rpm version than 1.6 for mandriva..:(
cheers
You may need modify the install shell file to omit the error of the writing permission. I had a similar experience. It is not a fan job to install EDA tool in the Linux.
