IAR and NXP LPC2378 Error while running Linker
pattenyl
Newbie level 1
iar error lp011
I am new to IAR and to NXP LPC2378 so I need some help :)
During compilation I get following error.
Error[Lp011]: section placement failed: unable to place sections/blocks with a total estimated minimum size of 0xb098 bytes in
<[mem:0x40000000-mem:0x40007fff]> (total uncommitted space 0x8000)
What does it mean? What can I do to solve the problem?
Thanks in advance Patrik
bobsanjose
Advanced Member level 1
Silicon Valley
Re: IAR and NXP LPC2378
you are working with the 32k free compiler version of IAR. Your code size is in the range of 50 KB according to the numbers you posted. That won't work. Either you eliminate some library calls or optimize your code otherwise to be smaller than 32k and this error message should disappear.
Bob
