I2C Master -Slave in Assembly
Latifa-UOB
Newbie level 2
Hello Every one ..
I realy need ur help to fine I2C Master (pic 16f876a) with Slave (pic 16f876a) code in Assembly for my project ...
If any one has a code or any sites to help me , i will be so grateful ...
Thank you very much ...
sky_123
Most people don't code in assembly these days. An alternative would be to use C code (which therefore isn't specific to your device, so you could use any I2C source code, there is a lot of it via google). If you really wanted it in assembly, then you could compile and use the assembly listing.
Latifa-UOB
Newbie level 2
THank alot for your reply ..
I tried to use C language but i faced some problem while i wrote my code , because of that i decided to use assembly within the C language in few things ...
Hope to gain any help from you ....
Thank you very much again...
