DatsAbk
Member level 3
Hello,
here is the code for master communication-
Here is the slave code-
There are 2 possibilities of error:
either my rs232 display code has an error or the error is caused as I haven't connected pullup resistors along the serial bus lines.
Kindly guide me on solving the problem.
My aim is to send data from master to slave and on receiving a stop bit the slave will communicate the data to rs232 port on my pc
#include <p18f46J11.h>
#include <i2c.h>
#include <delays.h>
#define I2C_V5
void send(unsigned char data)
while(!WriteI2C(data));
void main()
unsigned char x[]="Hello",i;
EnableIntI2C1;
SetPriorityIntI2C1(1);
OpenI2C(MASTER,SLEW_OFF);
IdleI2C();
StartI2C();
while(!WriteI2C(0x10));
for(i=0;i<5;i++)
send(x[i]);
while(1);
#include <p18f46j11.h>
#include <i2c.h>
#define I2C_V5
static unsigned char data[5],i=0;
void readbuffer(void);
void trx()
unsigned char x;
for (x=0;x<5;x++)
while(PIR1bits.TX1IF=1) //check if the transmit register is empty or not
TXREG1=data[x];
void chk_isr(void)
if(PIR1bits.SSP1IF==1)
if(SSP1STATbits.S==1)
PORTD=~PORTD;
readbuffer();
else if (SSP1STATbits.P==1)
_asm
GOTO trx
_endasm
#pragma code My_HiPrio_Int=0x08
void My_HiPrio_Int(void)
_asm
GOTO chk_isr
_endasm
#pragma code
void main()
TRISD=0;
PORTD=0X55;
EnableIntI2C1;
TXSTA1=0x20; //enable low speed 8 bit transmission
SPBRG1=0x15; //set baud rate=19200
BAUDCON1=0X00;
SSP1ADD=0x10;
OpenI2C(SLAVE_7_STSP_INT,SLEW_OFF);
while(1);
data[i]=ReadI2C();
i++;
