#include <18f4520.h>
#include <stdio.h>
#include <stdlib.h>
#include "lcd20x4.h"
#fuses XT,NOWDT,NOPROTECT,NOLVP
#use delay(clock=4000000)
#use I2C (master, sda = PIN_C4, scl = PIN_C3)
#define LCDADDR 0x70 // default slave address
#define ON 0x08
#define OFF 0x00
#define LCD_SET_BIT(x) fetch_data(x)
byte LCD_ADDR=0x4e; //I2C slave address for Funduino LCD module
//Transmittion data
void transceiver(unsigned char data)
i2c_start();
i2c_write(LCD_ADDR); //the slave addresse
i2c_write(data);
i2c_stop();
//Clocking the LCD's enable pin during transmit data
void fetch_data(unsigned char data)
data=data|0b00000100;//set pin E is a 1
transceiver(data);
delay_ms(1);
data=data-4;//toggle E back to 0
transceiver(data);
delay_ms(1);
void lcd_init()
//Request works on the command by set the RS = 0 R/W = 0 write
LCD_SET_BIT(0x00);
LCD_SET_BIT(0x10);
LCD_SET_BIT(0x00);
LCD_SET_BIT(0x00);
LCD_SET_BIT(0x10);
//First state in 8 bit mode
LCD_SET_BIT(0x30);
LCD_SET_BIT(0x30);
//Then set to 4-bit mode
LCD_SET_BIT(0x30);
LCD_SET_BIT(0x20);
//mode 4 bits, 2 lines, characters 5 x 7 (28 h)
LCD_SET_BIT(0x20);
LCD_SET_BIT(0x80);
//no need cursor on (0Ch)
LCD_SET_BIT(0x00);
LCD_SET_BIT(0xC0);
//the cursor moves to the left (06 h)
LCD_SET_BIT(0x00);
LCD_SET_BIT(0x60);
//clears the display
LCD_SET_BIT(0x00);
LCD_SET_BIT(0x10);
void lcd_clear()
LCD_SET_BIT(0x00);
LCD_SET_BIT(0x10);
// Need the backlight lid.
void lcd_backlight(byte state)
LCD_SET_BIT(0x00);
LCD_SET_BIT(state);
//Display the character on LCD screen.
void display(char in_data)
char data;
data=in_data&0xF0;
data=data+1; //set RS pin to 1
fetch_data(data);
data=in_data&0x0F;
data=data<<4;
fetch_data(data);
//Make the x/y pointer
void lcd_goto_xy(byte x, byte y)
byte ptr1, ptr2;
fetch_data(0x10);
fetch_data(0x00);
switch(y)
case 1:
ptr1=line_1[x]&0xF0;// stamp the high bit
ptr2=line_1[x]&0x0F;// stamp the low bit
break;
case 2:
ptr1=line_2[x]&0xF0;
ptr2=line_2[x]&0x0F;
break;
case 3:
ptr1=line_3[x]&0xF0;
ptr2=line_3[x]&0x0F;
break;
case 4:
ptr1=line_4[x]&0xF0;
ptr2=line_4[x]&0x0F;
break;
default:
fetch_data(0x80);
fetch_data(0x00);
break;
ptr2=ptr2<<4;
fetch_data(ptr1);
fetch_data(ptr2);
void main()
char led=0;
delay_ms(20);
lcd_init();
lcd_goto_xy(0,1);
display("ABCDEFGHIJKLMNOPQRST");
lcd_goto_xy(0,2);
display("12345678901234567890");
lcd_goto_xy(0,3);
display("AAAAAAAAAAAAAAAAAAAA");
lcd_goto_xy(6,4);
display("It's Work.!!!");
lcd_backlight(ON);
while(1);
