Register Log in
I2C hardware implementation
karthikkrv85
Full Member level 3
bangalore
Dear all...
I would like to know how the hardware part of I2C is implemented. I mean, consider data register is a buffer and each bits will be left shifted and transmitted in the SDA (with open drain logic). Similarly what kind of logic are behind the status registers and what are the gates, transistor or buffers are available.
Thanks and regards,
karthikkr
bigdogguru
Administrator
Southwest, USA
Are you attempting to implement a softI2C or bit banged I2C on a microcontroller? If so what microcontroller are you using in your design?
BigDog
karthikkrv85
Full Member level 3
bangalore
hai bigdogguru.. actually i am not trying to implement softI2C or bit banging type coding. I wanted to know the functionality of I2C hardware.
For example
1. a port pin of micro controller has a latch, one or 2 FET.
2. a serial buffer is having shift registers and transmits the data bit by bit.
Similarly, a I2C hardware constructed by what elements and how it is finding the status of the bus. I didnt find documents related to this details
bigdogguru
Administrator
Southwest, USA
    V
karthikkrv85
Full Member level 3
bangalore
Philips Semiconductors is actually the father of the I2C protocol:
The I2C-bus and how to use it (including specifications)
Almost everything you would want to know about the I2C protocol:
I2C Bus Website
There are FPGA implementations in both Verilog and VHDL available at:
OpenCores
BigDog
The first two link shows only about the software implementation. The hardware part is not available except open drain configuration. I think the status registers or clock configuration circuits to be presented to understand complete functionality. I am not going to do any research but i feel knowing these details will be good.
Sorry i know very little about FPGA's.. Anyway i have registered to download the design. it may take 2 or 3 days. Mean while i would like to know any other details related to my topic.
Thanks for ur kind reply...
Toggle Sidebar
